FPGA interface dynamic does not connect with FPGA interface based Vi
Hi all,
   I have to use a vi (using an FPGA interface in in its inpouts), in an other Vi (which call directly FPGA Dynamic ( when i opened FPGA reference and configure with an FPGA vi or a bitfile the FPAGA interface take dynamic by default)
  but i cannot connect the two vi by they FPGA references (plz see picture).
  did anyone had had this problem before and what is the solution for that?
SASA
Message 1 of 11
(5,985 Views)
Hi SASA,
use a typedef for your FPGA reference. Use that typedef in your subVIs and in the OpenFPGARef function call ("Bind FPGA host reference to typedef")…
Message 2 of 11
(5,979 Views)
Using a Dynamic FPGA Reference is now considered preferable to using a type definition.
You need to modify the FPGA Reference control on the subVI to accept a dynamic VI reference, which you can do by right-clicking on it, then configuring it to accept a dynamic reference containing the controls, indicators, and methods that the subVI accesses on the FPGA.
Message 3 of 11
(5,963 Views)
Hi GerdW,
  Thank you.
  it works with your solution, but it create another problem with another vi (see picture).
SASA
Message 4 of 11
(5,920 Views)
Hi SASA,
you need to use that typedef in each instance you operate on this FPGA ref…
Message 5 of 11
(5,910 Views)
OK, i got the point, but the solution that
Message 6 of 11
(5,905 Views)
Hi SASA,
nathan's solution is proposed for current LabVIEW versions. As I'm limited to LV2011 I cannot comment on this one.
Edit/Correction: Even LV2011 has this "Dynamic FPGA Interface Cast", but I didn't use it so far…
Message 7 of 11
(5,898 Views)
Sorry, it's not a right click option. Instead you should create a control or indicator from the dynamic FPGA reference wire, or use the Dynamic FPGA Reference constant and change it to a control as explained here:http://zone.ni.com/reference/en-XX/help/371599K-01/lvfpgahosthelp/fpga_dynamic_host_interface/
Note that you can make the dynamic reference a type definition which may be helpful if you're using it in multiple places.
Message 8 of 11
(5,888 Views)
i got the point, just creat controls on the FPGA interface wire and configure to use dynamic mode.
but i saw in the link that its a help page for LV 2014. is it working for LV 2013 i'm using ?
Message 9 of 11
(5,870 Views)
nathan, can you please see the picture attached, it describe that i cannot find  the dynamic box in the configuration
Message 10 of 11
(5,860 Views)
