FPGA is missing in the Add Targets and Devices
Hi All,
I need to develop for a PXIe 7841R borad in LabVIEW 2015 yet I cannot find the FPGA hardware in the Add Targets and Devices menu despite i have installed the:
 - FPGA module
 - Xilinx compiler (indifferent for this step)
 - R-Series module
 - RealTime module (Probably useless for my purpose)
 - cRio module (Probably useless for my purpose)
Attached below the situation in my MAX and the Add Targets and Devices window.
I have some doubt on that PXI platfom services runtime 17.5.1
Many thank in advance
(1,531 Views)
Accepted by topic author ico82
I think the window you are seeing is the Add Targets and Devices menu when you right-click the project item in the project explorer. If you try to add a target under the My Computer item, do you see options for your R-Series board?
(1,481 Views)
Quoting the ZZ top "me so stupid"... It is some years that i do not develop on embedded devices.
Many thanks Jacobson
(1,468 Views)
