FPGA library linkage breaks
Hi All,
I've developed some FPGA code on the 32 bit myrio FPGA platform 2019 and all works well for a while but occasionally the linkage of the FPGA subVI's (on the Labview FPGA side) fails and the VI breaks. I then need to re-complile the directory including the FPGA code to re-establish those links. Following that i need to re-compile.
Any ideas why this might be the case ? My only concern is that I also run a Labview 2020 64 bit for another application running at the same time. Could i be that the two are cross-confusing linkages to the proper FPGA sub-VI's ?
Cheers
Jamie
(1,464 Views)
There shouldn't be cross linking, check dependencies in case there are https://www.ni.com/docs/en-US/bundle/labview/page/avoiding-incorrect-dependencies.html
One thing that may reduce the save requests is to separate source and compiled code https://www.ni.com/docs/en-US/bundle/labview/page/separating-compiled-code-from-vis-and-other-file-t...
Regarding the recompile requests, I'd point to the bitfile and not the VI in Open FPGA VI.  This way even slight loading changes (i.e. not logic) does not ask for a recompile.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,430 Views)
Hi Terry,
Thanks for your prompt reply. I'll take your links into account and point to the bitfile instead of the VI in future. I should point out though that the subVI's missing were the FPGA VI's related to timing etc that come with the FPGA distribution (loop timer etc). I dont know why their links just break on occassion.
Cheers
Jamie
(1,385 Views)
