FPGA phase shifter and comparator
I am trying to implement an FPGA program (on Labview 2010) that takes an input signal, phase shifts it by a user-controlled amount, and outputs a square wave with the same frequency as the input signal.  Does anyone have suggestions as to how to approach this?  Any help would be much appreciated.
  - Ethan
(3,181 Views)
Hi Ethan,
I would do it the following way.
1.) Find high/low period of incoming singal
2.) using a sequence and wait functions reproduce the signal
Joe Daily
may the G be with you ....
(3,166 Views)
