FPGA project - custom cRIO module driver development
Hi!
I'm developing the driver for my custom cRIO module. The module has 4 analog input channels.
After analog-to-digital conversion I need to transmit the digital data via the cRIO bus.
I placed an FPGA I/O node on my block diagram (see the attached image), but I can only read if the pin's state is HIGH or LOW, not the value of the ADC.
How can read the value of the conversion?
Thanks for the help,
Levi
Message 1 of 1
(2,570 Views)
