FPGA save for previous
I recently needed to save a LabVIEW FPGA 8.6 project to LabVIEW FPGA 8.5 and encountered a mess!
I crashed LabVIEW many times before I found the culprits.
To convert from FPGA 8.6 to 8.5
1.) Remove all express VIs - the timing and interrupt VIs are express VIs.
2.) Remove all FPGA references from the Host VIs -  as the references are different between these versions.
3.) Save for previous.
4.) Replace deleted express VIs
5.) Replace FPGA references in the Host VIs
6.) Recompile
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 1 of 1
(2,554 Views)
