FPGA setting panel control
Hi all,
I´m quite new in Labview and experincing some difficulties 🙂 I have a compex FPGI.vi with many controls .
One of the panels (Advanced Settings)  is devoted for advanced users and should interactively controlled with a switch to hide/unhide it
I tried to implement the following code which anyway does not work under the FPGA. VI ; it does under the host.vi but then I shuold exchange all the panel data (see below ) with the FPGA itself and as I said I´m not a master of it
Coudl you advice an approch directly in the FPGA.vi or anyway an easy alternative
Thanks in advance!
(1,219 Views)
FPGA VI and Host VI are programmed differently. It is not recommended to interact with FPGA VI directly. The proper way would be to write a Host VI that accesses FPGA VI through FPGA Interface API. See Getting Started with LabVIEW FPGA
(1,168 Views)
Thanks for the feedback
(1,134 Views)
