FPGA signal acquisition
I'm working with a team of engineers on a 3-dimentional 'sonor camera'. In order to achieve this project, we need to do the acquisition of 80 analogic sound signals (each of 250 kbits/s from microphones). I am wondering if any of you tried to configurate an FPGA with LabView to process such a task.
I would really apreciate any feedback (experience or simply comments) on the feasibility of this project.
Thank
Jean-Yves Breton
PolyProjet École Polytechnique MTL
(2,566 Views)
The first consideration here is getting 80 analog inputs into a single chassis.  For this, you could use a 4-slot chassis, with at least 3 of these 32-input analog input modules.  There are also 8-slot chassis, if you require more inputs for other purposes.  As far as FPGA coding is concerned, there shouldn't be a problem running a loop with all 80+ analog input channels.  We may run into a bottleneck here depending on how fast you need to sample these channels.  The 9205 is capable of 250kS/s aggregate sampling rate which means that you can run 1 channel at 250kS/s, 2 channels at 125kS/s each, and so on.  If you need to sample all 80 inputs at a rate of 250kS/s, you will probably have to use something like the 9223 module.  The downside to this is that there are only 4 inputs on this module, so getting up to 80 channels may be a bit of a limitation here.  Is this the sampling rate you'd like to run?  If you could go with a lower sampling rate, the first suggestion will be your best option.  Thanks for the question!
(2,543 Views)
You may look at the flex rio products. Higher end and higher speeds.
(2,530 Views)
Thanks alot for those answer, we are now considering all of those options. Any other idea will be appreciate!
Jean-Yves Breton
Polyprojet
(2,520 Views)
