FPGA sine wave on the myRIO audio out?
I want to generate a roughly 200mV 50Hz sine wave on one of the channels of the myRIO audio output. I want to use the FPGA on the myRIO to save CPU space. I am struggling to find a solution. I have attached my main.vi. I am also brand new to labVIEW.
Regards
(2,940 Views)
Accepted by topic author AKid
Hi AKid,
is that VI meant to run on the FPGA? Are you sure all those functions/ExpressVIs are allowed for FPGA programming?
Did you compile this VI for FPGA? Did you get any error messages while trying so?
Did you notice those learning resources offered in the header of this LabVIEW board?
I suggest 3 steps:
1. Learn LabVIEW basics.
2. Learn LabVIEW-RealTime basics.
3. Learn LabVIEW-FPGA basics.
(This may sound harsh, but is good advice from own experience.)
(2,934 Views)
Hi AKid,
It's probably best to put this on the RT or the host computer.
Is there a reason you want this done on the FPGA? That's used for simple and fast computation usually because there is such limited space on the chip.
Best
David
(2,903 Views)
(2,902 Views)
Hi Guys,
Thanks for the advice. I did the FPGA module at ni learn and got what I needed to know. I have another question.
So I can generate my sine wave on the fpga and in the host VI, I can change my amplitude and frequency through the front panel in real time, however, when I make this host VI a sub VI to use in my main.vi, as attached below, it doesn't change the variables in real time. What am I doing wrong? Regards
(2,879 Views)
Hi AKid,
Did you also take the (core) LabVIEW basics course?
THINK DATAFLOW!
Your "subVI" has a loop (minor fail) and waits for user input (big fail).
As the subVI does NOT open its frontpanel the input can never occur! Moreover you are using a headless RIO device: there is no display to show any frontpanels…
Simple solution: integrate to code of your subVI in the MainVI.
(2,875 Views)
