FPGA spartan xc3s100e compilation problem
hi!
I've tried to programing with labview to Xilinx spartan3e xc3s100e with Parallel port  kit. I have lot of problem.Because of  the kit has  parallel port. I don't know what to do. I have to do  that. How can i programing this kit. Help me...
I need the following.
-machine name for parallel port.
-port number for parallel port
(3,556 Views)
when the program runs,I take a error message by labview error window. "there is no communication between the device ang the PC (error code:305001)". But, the device already has been connected.
(3,551 Views)
Could you please explain how you have integrated this chip into LabVIEW? The LabVIEW FPGA Module is not designed for integration with non-NI targets. While NI may use a Xlinx family of FPGA chips, we do not have open source integration for all Xlinx Spartan targets? Is this Error in LabVIEW? Windows? How has the project been configured?
Please attach as much information as possible about the system, as that will give the greatest chance at reaching a timely resolution.
Thank You,
Patrick Corcoran
Application Engineering Specialist | Control
(3,507 Views)
Hi
Thank you for your answers.
installed programs:
Labview 8.6 professional dev. system
Labview FPGA module for 8.6
Xillinx spartan-3e Labview Driver.
Operation System:
MS windows xp prof. with SP2.
Hardware:
Basys Xillinx Spartan3E- xc3s-100E   FPGA kit (The hardware has a JTAG progamming port. But, parallel port (LPT) cable included).
The Problems :
I constituted a new project according to the document (Getting Started With LabVIEW FPGA ). I didn't have a problem in this step until, I clicked the Run button of the Labview working page.
When I clicked  the run button, Generating Intermedia file window was appeared.it was passed successfully.And then compiling VI for FPGA window was appeared. And, Labview FPGA complile server 8.6.0 was appeared.After a while the Compile was Completed.Later, When I clicked the Run button again, an error window was appeared in Labview  (error code 305001) I attached the view of the error window.
Can not  I download in the my hardware because of, I have the kit which parallel port ? How will I do it ?
Thank you
best regards.
Ercan Cosgun
(3,486 Views)
1245,
The Spartan 3E Starter Kit support does not support using a JTAG interface other than the USB-based one that's built into the board.
(3,178 Views)
