FPGA subVI nonresponsive
I have nonresponsive subVI's in an FPGA project.  I copied a section of code that previously worked and added some simple waits in a flat sequence structure (no change to the code affecting the subVIs) into a new parent FPGA VI and the subVIs are no longer responsive.  There are no simultaneous calls, but it is checked for reentrant calling.  I also recopied the original subVIs into a new file with a new name and still no response.  Does anyone have any suggestions?
(2,612 Views)
What do you mean by "no response"? How do you communicate with those subVIs on the FPGA? Usually, you won't have much control over subVIs on a FPGA..
It might also help if you put some of your code here if that is possible at all.
LabVIEW 2012 32 bit
I am not an expert!
(2,597 Views)
