FPGA target compiling failed
Hi all,
I met a problem when I tried to compile my FPGA target VI. The compiling failed for some reason halfway after the compiling started. I post some screen shots of the error information from the labview.
23886iC7D6DCFE6863CC4D
23888i92597A350CC0A2CA
23890iFE25FFFFF97C6A3F
23892i0D0D078B55284EC0
23894i32E13F65C2E20BDB
23896i6A044045F7C44DB4
23898iD6587FA96497B008
What may causes this problem? How could I fix it?
Thank you very much!
Kind regards,
masterwho
(4,784 Views)
as the compiler says, your program is too big to fit inside the FPGA.
Your program is using 151.6% of avalible Flip Flops, that is 51.6% too many.
You need a larger FPGA or redesign you program to use less Flip Flops / slices.
(4,767 Views)
Thank you very much for your reply. Could I ask that what do you mean by larger FPGA? Do you mean FIFO which has larger number of elements?
Thank you again!!
(4,751 Views)
No, not the FIFO's.You can get FPGA's in different sizes.
But one of the things you can do to reduce the amount of Flip Flops that your program is using, is to reduce the size of the FIFO's.
Try to figure out if all your FIFO's has the right size or if some can be reduced.
(4,745 Views)
If your FIFOs are memory-based, changing their size will not reduce your flip flop use.  However, if you are using logic-based FIFOs, you might be able to save space by reducing their size or changing them to memory-based.
By different-sized FPGAs we mean the number of gates; for example, NI lists some of their Virtex-II FPGA cards as 1M gates and others as 3M gates.
(4,728 Views)
Accepted by topic author masterwho
Also are you having large arrays on the front panel of the FPGA VI ?
Or are there large arrays inside the code ?
If you can, post a snipet of your code.
(4,721 Views)
Hello dkfire. Thanks very much for your help.
You are right. I used a too large array in my code. It works after I decrease the size of array.
Thank you very much!Smiley Very Happy
(4,707 Views)
