09-10-2013
03:30 PM
- last edited on
03-25-2025
10:40 AM
by
Content Cleaner
@nathand wrote:
@michaeljoseph wrote:
We (my advisors and I) think that the summing pairs approach would preserve more information than simply throwing away every other point. Also, we can avoid overflow because each 16-bit number only contains 12-bits of actual information. The 16-bit number will just need to be divided by 16 before summing because the 12-bits of information are placed in the 12 MSBs of the 16-bit number. Does that sound right?
Depends on what the code is actually doing, but generally if you convert a 12-bit value to 16 bits, the useful bits are stored in the low 12 bits so that the value remains constant. No division by 16 should be necessary.
The NI 5772 manual says that the 12 bits in the 16 bit number are left justified (foot note on page 16, https://www.ni.com/docs/en-US/bundle/ni-5772-seri/resource/373625b.pdf). I assumed that left justified means that the 12 bits are moved over so that they occupy the 12 MSBs. That's where I got the idea of dividing by 16 before adding the numbers. Does that sound right? It seems to be working, but I could be missing something.
09-10-2013
03:55 PM
- last edited on
03-25-2025
10:40 AM
by
Content Cleaner
Seems like you have it right, sorry for the confusion. I haven't worked with a 5772, and I haven't seen many other analog input devices set up that way, but there's probably some advantage such as avoiding the logic needed for sign extension.
