FPGA with Labview 2017 SP1 in windows 10
I am working with NI cRIO 9014 along with 9104 chassis. I want to work in LabVIEW FPGA for servo motor control. I am using LabVIEW 2017 SP1 as it is compatible with my crio. But the problem is, I can't install Xilinx compilation tool 2015.4 and ISE 10.1 as these are not for windows 10. Is there any way that I can use LabVIEW FPGA with LabVIEW 2017 SP1 in windows 10?
Thanks in advance.
(1,736 Views)
You can setup a build server with Windows 7 which you can install ISE.
LabVIEW FPGA would generate the intermediate files and then it would be directed to send to the server which will complete the compile.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,732 Views)
Thank you very much for your reply. Unfortunately, I don't have enough recourses to run parallel OS . If there is any possible way to do it in windows 10 that would be the best for me.
Nisatuz Jahra
(1,719 Views)
This could be a separate computer as seen here https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6x5SAC
You could use the NI Cloud Compile https://users.niwsc.com/compilecloud/#/
ALE Consultants
(1,703 Views)
AFAIK, you do need a valid maintenance contract however to be able to use the cloud service, which I think is a fair requirement. Another option might be to use a Virtual Machine in which you install Windows 7 and your Xilinx toolchain and then use it as local compile server in your real development system.
Rolf Kalbermatter  My Blog
(1,693 Views)
