FPGA
Hei, I am new in LabVIEW Programming. We are running a project at the university and having some challenges with compiling.
We have to compile the FPGA every time we open the project. In the end of the day the folders are zipped, and then uploaded at dropbox. Next day the zipped file is downloaded, unzipped and open again, but then do we have to compile the FPGA again. Does anyone know the reason for this?
Thanks a lot!
SHK
(3,474 Views)
Hi shk,
the bitfile created by compiling usually is located in a different path than the LabVIEW project.
When you ZIP your project folder you miss the bitfile and so have to recreate it the next day.
Possible solution: store the bitfile inside the project folder. To do so you have to change the compilation settings...
(3,471 Views)
Thanks, GerdW!
Have a nice day! 🙂
(3,468 Views)
Incidentally, if you're unzipping to a different path at any point, you might find this is an issue:
http://digital.ni.com/public.nsf/allkb/B76C5ED987F464EC862579750059A761
CLA
(3,446 Views)
Thank you, thoult! Now we dont have to compile every time anymore:)
(3,415 Views)
