FPGA
I want to run a simple math VI on an FPGA target(cRIO 9068).  VI compiled sucessfully and the bit file is generated. But when I run the VI on FPGA target, it shows the error "LabVIEW FPGA called another software component, and that component returned the following error:Error -63034 occurred at niFpgaOpenAndRun_cRIO-9068.vi
Please suggest a solutin
Shaji
(4,668 Views)
show your VI and how you call it to get help...
(4,645 Views)
Project files attached
(4,631 Views)
Created the bit file and run the VI using run button to run it on FPGA
(4,627 Views)
That is almost completely useless.  The project file does not contain any code.  Please put your entire project (or at least the relevant parts) in a zip file and post that.
(4,617 Views)
Please see the project zip. sorry for the mistake
(4,610 Views)
How are you running this FPGA?  Where is the RT code that is calling it?
(4,593 Views)
