FPGA
Pls help on how to connect a cluster to a FPGA Read/write control.
(3,921 Views)
Try posting some more information with your requests in future - like posting your VI.
Did you name your cluster? The read/write control works on named items, so if your cluster doesn't have a name, you won't be able to select it on the read/write control.
You should also be aware that clusters are not recommended for FPGA programming as they use more fabric/resources: http://digital.ni.com/public.nsf/allkb/80C9808E454DCBC286257093005B9EB6
(blog)
(3,906 Views)
Thanks for your response.
I have already named the clusters,even then they are not listed in the R/W FPGA Control.
Pic attached.
(3,900 Views)
You need to post your FPGA VI (not a screenshot) - do you have those clusters on the front panel of your FPGA VI?
(blog)
(3,881 Views)
Thanks again.
I found that i did not name the cluster in FPGA VI,thus this issue.It is resolved now.
May i ask you 2 more questions pls.
1)As this is my 1st FPGA project,i am developing the project by refering to a Video online by NI.I have created a FPGA VI and developing a Host Vi.
I will dump the FPGA Vi in the FPGA mod and control it from the Host Vi which will be running in my CPU.
Pls let me know if what i have explained above is right.
2)I am using a CRIO 9073 with  9237,9401,9505 Mods.9237 has to be calibrated for full bridge.Pls help me on jow i can do it.
3)In the lv.jpg,whether the highlighted ones are local variable???I have to recreate that part of code,i considered that to be a local variable,when i recreated it,it looked different as shown in lv1.jpg.
Pls guide.
(3,873 Views)
