FPGA
I'm almost new to FPGA. I should use an express VI to acquire and send data by i2c communication and a FPGA part to convert that values in order to have 2 parallel processes (acquisition at high level and conversion at low level).
- i2c low level implementation is very difficult: each example on internet doesn't suit me. I tried some changes but it didn't work.
- Furthermore, I can't convert values at high level beacuse too much time is required
An error is shown: -61206 Read/Write Control in myRIO v1.0 Configure I2C.vi->RT Main.vi
Surfing the net, I found that is due to: The configured item does not exist. What does it means exactly?
What I should do to solve this problem and use high and low level in parallel?
Best regardes,
Leonori Chiara
(3,388 Views)
Can  you attach the code you are using that produces this error?
(3,359 Views)
In attachment:
- High Level: RT
- Low Level: Reduced Calculations
(3,350 Views)
