FPGA
When I compile my FPGA .vi using the local compile server, an error occured. As shown in the figure below。
(3,457 Views)
What target are you trying to compile an FPGA for?  What version of LabVIEW are you using?  Which Xilinx compilers did you install on your machine?
(3,439 Views)
Hello! My target  is PXI-7953R,The version is LabVIEW 2015 SP1;I have installed ISE 14.7.Thank you !
(3,424 Views)
