FRA log sweep showing zero at startup
Hello
I made a vi for the FRA data logging and it is already posted. There is one mistake is showing that, when I am sweeping in log(10steps/decade), in the starting of sweep two three steps it is showing all zero values. like as below
eg:
freq,mag,phase
0.10,12.31,-179.8
0.00,0.00,0.00
0.12,7.31,-179.3
0.00,0.00,0.00
0.15,6.35,-178.23
after that it is running correctly
In the plotter which I made is showing this zero values but in the data which is saved the zero values are not there.
In the LIN sweep, there is no problem.
I cannot probe the problem.
Please help it is very important in frequency response analysis
thank you
"Thanks with regards "
by
..........Gireesh..........
Message 1 of 1
(2,415 Views)
