FRC 2012 cRIO project error
We have LabView running but when we try to create the FRC cRIO Robot Project we get an error that a vi is missing.
Hardware: FRC cRIO I  (not II)
Installation sequence:
installed LabView {everything} (from USB Drive from 2012 Kickoff) and activated with S14X86759.
installed the FRC 2012 LabView Update from NI website.
installed the FRC 2012 LabView Utilities Update from NI website.
installed the FRC 2012 LabView Driver Station Update from NI website.
Could you confirm that we have to setup the cRIO, Axis Camera and Robot Radio (per Getting Started list of tutorials) before creating that project?  If this is the reason for the error, is there ANY other way to virtually setup the RT hardware WITHOUT having to physically connect to it first?
(2,410 Views)
Please post FRC questions in the FRC forum.  Also, probably not a good idea to post your serial number.  Finally, when you report an error, please be specific - which VI is missing?
You do not need to have any hardware to create a cRIO Robot project.  The hardware is only necessary when you want to run the code.
(2,409 Views)
