FREEWARE - Sample program available
I agree with you about microsoft being bad. Please tell me what you think of my program whenever you get a some free time.
Message 11 of 26
(6,336 Views)
I haven't downloaded your program, but I was working on something similar that used the Terraserver database and .NET.  I gave up on it as soon as Google Earth came out.  That is a great program.
Message 12 of 26
(6,327 Views)
That's a nice (and huge...) work. I also started a similar project, but I'm still far from this. 🙂
Still a lot of wiring to improve ;), but gives already impressive results. There is a lot of stuff inside that's will be worthwhile to study !
Thanks for sharing, adn 5 stars !
Apart these comments, what sort of feedback are you waiting for ?
Suggested improvement of the user interface (sure these are things you already thought about ;)):
update the display as soon as a parameter is modified. ie, suppress the GO button !
add a distance scale, and a grid overlay,
display the pointer coordinates,
offer  the possibility to center the display on a selected point to help zooming in...
The tiling seems buggy around the edges : there are problems with some map/photo series connections. Can you comment ?
Chilly Charly    (aka CC)
Message 13 of 26
(6,323 Views)
Wow!
Feedback:
Nice code.
Ditto CC.
If you really want to do something that I believe is just not available anywhere outside of the government Smiley Wink is to enhance this nice piece of work by making it 3-d.
In this thread post #32
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=183&jump=true
 I posted a zip and discusion of how I rendered my model train layout in 3-d. In that example, I use a picture (like you) and use it to dicate the color at each location on the surface.
The surface is defined by a hardcode front panel control that I fat-fingered to define my layouts topography. Now if we could read the topographic map/lines and use it to define the topography of the photo.... use your photo and topographic info to feed my viewer...fill in the blanks.... a miracle occurs...
We could do virtual fly throughs of our neighborhoods.
Nice work vivi.
You deserve another set of stars.
Ben
Message 14 of 26
(6,312 Views)
Thank you all for replying with your thoughts.
I am looking for what else the program should have that I haven't thought of and also for any bugs that I missed.
what is wrong with my user interface? please tell me so I can fix it.
The reason I do not update the picture each time you change something is that most times that you change 1 of the controls you are going to change at least 1 more as well and it takes a fairly long time to update the picture.
I like the ideas of a scale and grid option.
I am currently working on pointer coordinates.
I will more than likely get around to having the coordinates be for the center tile.
the only bugs that I have seen about edge tiles witch are in a different UTM zone.
Thanks again
Message 15 of 26
(6,296 Views)
hi all i just finished a new version of my map program.
please tell me what you think could make it better and what you think is wrong about it. here is the url.
http://www.Culverson.com/Public/NewTerraView.zip
Message 16 of 26
(6,234 Views)
Very cool!  It would great if you could use one of those free online services to convert a place to a lat and lon instead of manually looking it up yourself.
Keep up the great work!
Message 17 of 26
(6,230 Views)
I didn't get any errors, but I didn't really get anything.... it wouldn't load any of the images.  I only got 'invalid scene id' in the map blocks!  Sorry!
system:
p4 3.2GHz
512mB pc2700
LV 7.1 Express
Quicktime
static ip
Message 18 of 26
(6,211 Views)
show me the front panel when it gives you that message
Message 19 of 26
(6,207 Views)
Reallly is,
Its a really fantastic work, impressive!!!!!!!!!
Its a real champion work, keep going!!!!
dont mind i am replying so late, but i just ve seen this, so.........
Congrats!!!
thanks,
Nishant
Message 20 of 26
(6,196 Views)
