FT240x en mode bit bang
The VI provided by FTDI allows me to use the FT240x in Bit Bang mode (see attached file).
I try to control the outputs D0-D7, but I do not know the data to be written into the buffer.
I watched the construtor documentation, forums, I tried numerous value but my outings did not change state.
The Vi works, he read out, reset the circuit.
Anyone know the command to enter?
Thank you in advance.
(3,158 Views)
For this question, you should contact the manufacturer of your device, which wrote this VI. Ask them to provide examples of use of this VI.
Only the documentation provided by the manufacturer can tell you how to use the device.
Pierre-Emmanuel BELLES
Certified LabVIEW Developper
Certified TestStand Architect
(3,128 Views)
