FTC Template Dependancies not found...
I'm trying to load the LV_TeleOp_Template.vi and LV_AutonomousTemplate.vi for FTC, however despite having the 2011 FTC Toolkit installed, I seem to be missing some of the subprograms / depenencies required by the program.  In particular, it can't find the following:
FTC Move Servos.vi
FTC Move Motors.vi
NXT ReadMessage.vi
I'm completely new to FTC, so any help would be great!
Many thanks!!!
Message 1 of 11
(3,660 Views)
Please make sure that you follow all the steps in the FTC Software Setup guide. The VIs that you mentioned are part of the NXT Module for LabVIEW. Make sure you have that installed. Also, please post FTC related questions to the dedicated FTC Community Page. This will make sure that all the solutions related to FTC issues are concentrated in one forum and are shared with other members of that forum.
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
Message 2 of 11
(3,650 Views)
Hi Sev,
Thanks for your help with this.  I tried installing the NXT Module for LabVIEW and following the FTC Software Setup guide, but the FTC Move Servos.vi is still not being found.  Any ideas?  Also, I will make sure to post any new questions to the FTC community page.
Many thanks,
Darren
Message 3 of 11
(3,640 Views)
Hi Darren,
Were you able to find the FTC Move Motors.vi? If so check the location of this VI to see if the FTC Move Servos.vi is located in the same folder.
Sev K.
Message 4 of 11
(3,632 Views)
Hi Sev,
Sorry for the late reply!  I searched my computer and couldn't find the FTC Move Motors.vi either.  Does that provide any clues?
Many thanks,
Darren
Message 5 of 11
(3,624 Views)
Hi Darren,
Could you attach the VIs that your are trying to open.
Sev K.
Message 6 of 11
(3,618 Views)
Hi Sev,
Files are attached.
Thanks for looking into this!
Best,
Darren
Message 7 of 11
(3,615 Views)
Hi Darren,
Could you reupload the VIs or let me know in which folder they are located on your computer. They might be a part an older version of the NXT module.
Sev K.
Message 8 of 11
(3,609 Views)
Also, the NXT_ReadMessage.vi should be located here: C:\Program Files\LEGO Software\LEGO MINDSTORMS NXT\engine\vi.lib\LEGO\BlockSupport\NXTToolkitLibrary\Message. Check that path on your computer.
Sev K.
Message 9 of 11
(3,607 Views)
Hi Sev,
Here are the files!
Let me know if you need anything else.
Many thanks,
Darren
Message 10 of 11
(3,603 Views)
