FTDI VCP Problem read
I´ve designed an aplication based in the example of "Multithread_serial" that reads packet of 120bytes data transfered every 20ms over a specified Serial COM port. This COM port is "emulated" by the FT232R of FTDI which recives the data from a MSP430 , in serial way (Tx and Rx), and the PC access it as a VCP. The probem is that most of times i recieve data with a missing packet or signal or with very high "glitches" like this:
No matter if i set the COM speed to a lower value, i´ve tried with 230400 Baud first, after 115200, 57600, reducing the size of paket (60bytes), and the time between pakets to 80ms, and the problems were still there, i set a lower latency value os the COM port and nothing changed. Most rare thing is that one time in a 100 the system seems to work properly, with the same settings: pakets of 120bytes every 20ms at 230400 baud. (The first part of this singal its not periodic because it was updating):
If anyone has any idea of what is happening it would be really helpfull, i think maybe its a problem with FTDI drivers, im using the version 2.08.30 for Windows (downloaded from FTDI web page), and Windows 8.1
(4,390 Views)
Have you verified the effectiveness of the shielding on your cable? Try to make sure its only connected to ground on one side of the cable.
(4,372 Views)
Is there anything that is distinguishable about the packets generating the spikes? Do the packets include check sums or CRC that you can use to verify their validity?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,361 Views)
Thanks for your response, this is the scheme of the system, i´ve skipped the ADC stage by connecting directly uC to the Ft232R for testing only the serial com. and i´m generating a square signal in the MSP430, and converting it with the same Labview application.
(4,322 Views)
I see two ground connections.
Are you sure you don't just have a ground loop?
You should make sure that you don't have a circular ground connection, making sure the serial cable isgrounded only ont he side of the PC would be a good place to start.
(4,314 Views)
