FTDI invalid handle on some computers
@dkim2 wrote:
Yes.
This is the real problem! FT_Close is defined as:
FT_STATUS FT_Close(FT_HANDLE ftHandle);
NOT
FT_STATUS FT_Close(FT_HANDLE *ftHandle); // WRONG
Change that Pass: Pointer to Value to Pass: Value, et voila! It works! And yes, for the FT_Open() it needs to remain as Pass: Pointer to Value.
When I install the driver, the file in syswow64 is the ftd2xx.dll not ftd2xx64.dll, although I am using the call library function on the ftd2xx64.dll from LabVIEW. Could this be an issue?
SysWOW64, despite its name, contains binary files for 32-bit applications! The 64-bit binaries are located in System32! And I have no idea what you are talking about with ftd2xx64.dll. They are both called ftd2xx.dll.
Rolf Kalbermatter  My Blog
Message 11 of 14
(584 Views)
@rolfk wrote: I have no idea what you are talking about with ftd2xx64.dll. They are both called ftd2xx.dll.
Hmmm, on my PC the officially deployed from FTDI and signed library is also called ftd2xx64:
ftd2xx.dll is not exists in %WINDIR%\system32, at least not on my PC.
Message 12 of 14
(574 Views)
As the image shows in the other message for the device properties, it seems to have installed ftd2xx.dll in both SysWOW64 and System32. It's what I have observed in some systems too, but I'm not currently using any FTDI hardware.
The latest driver 2.12.36.4 from FTDI seems to indeed install the ftd2xx64.dll in system32. Go figure.
Message 13 of 14
(570 Views)
Thank you so much, this solved the issue.
Message 14 of 14
(533 Views)
