FTP PUT file - remote path
Hi all,
I want to use  FTP PUT file function for one of my application.
I am writing a binary file from my PC to the hardware memory.
I want to know , what input should be wired to remote path.
Because in this case, the memory is not divided into drives.
Presenty I am not able to perform the operation from LabVIEW.
If I am using Windows command prompt, I give put (filename) command after opening the FTP session.It is working fine also.
SajK
(5,752 Views)
Hi SajK,
Do you have the "NI internet toolkit", if not, I'm sory I can't help, but if yes a few weeks ago I developped a small utilitary that can copy file form/to a Windows based PC to an RT target through FTP. It is not difficult.
If you have the toolkit, I'll try to find and post a few VIs
Regards
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(5,744 Views)
If I remember well, you have to put the full path in"target file", I mean not just the path of the folder you want to pute the file in but "folder/file_name"
Epictetus
Antoine Chalons
(5,745 Views)
Hi TiTou,
Thank you for the reply.
I am having internet tool kit. Your example programs will be useful for me.So kindly send it.
Still I am not clear how to give the remote path if I am writing to a ROM of limited size.(may 5MB size).
SajK
(5,741 Views)
to be clear with the path you need to enter, you should try out the NI example,
Go to Help >> Find example... >> and search for "FTP"
You'll find a very good (but a bit complicated) VI, with it you should be able to place some probes and see the remote path you have to enter.
Also, I will try to find the VI I made... sometimes I'm being messy Smiley Sad
Epictetus
Antoine Chalons
(5,735 Views)
There we are... I didn't take time to re-try it, this was made to copy a folder and its whole sub-hierarchy to an ftp target so you might have to go to see in the sub vis to see how it works.
Tell me if you need more comments on the code 😉
Epictetus
Antoine Chalons
(5,731 Views)
