Facade VI opens dirty
My own issue is with the Display State Change, which is fired when the XControl is loaded, even though the comments in the facade template don't indicate that it should be fired in that case. One idea I have now, based on your latest post, is to use the First Call? primitive and only set the state changed boolean if it's false. This should presumably handle the case where the control is loaded, but I would have to check that. I'm assuming this should probably also work in Tim's case.
___________________
Try to take over the world!
Message 21 of 23
(493 Views)
That's similar to the workaround I added earlier in this thread where I just ignore the events if they happen when the owning VI is not running.
Tim Elsey
Certified LabVIEW Architect
Message 22 of 23
(490 Views)
Hi Tim.  It seems like for now, the workaround is the best solution.  I know that it's not ideal, but it does prevent the hassle of having a dirty VI.
Che T.
Message 23 of 23
(479 Views)
