Facing an issue of Add/remove software in NIMAX under Remote systems
When I am trying to click Add/remove software in Nimax under Remote systems , I am getting an error of SSH must be enabled on the target. Eventhough It is Enabled, It showing same error. Below Attached screenshots of errors I am getting while trying to click add/remove software option in  Nimax.
Can any one tell me how to resolve this issue.
Sai Nandini
(1,627 Views)
I Need to install  some of the packages, But That packages page is not getting when I am clicking the Add/remove software option. Can Any one tell me how  to solve this issue.
Sai Nandini
(1,615 Views)
Accepted by topic author Responsibility$2003
Based on the IP address of your cRIO, I guess it is connected to your host PC directly. To use Linux RT System Image installation, the Linux RT target itself must connect to the internet.
See Miscellaneous Failure When Installing Software to a Real-Time Target
Alternatively, you can refer to Installing Software to Offline NI Linux Real-Time Targets
https://tmesystems.net/
(1,573 Views)
Thank you for the answer, I will check it once.
Sai Nandini
(1,547 Views)
