Facing memory error during shifting from 3d stem graph to 3d surface graph in labview 2010
hello all,
earlier I was using 3D Stem graph in labview 2010. Now we want to move to Surface plot for same data.when i am trying surface graph it shows memory error.
I have  10240 data.
I was using vector method in stem graph so now for Surface graph i have thought that i have to make matrics of 10240x10240 and its diagonal elements should be my Z co0ordiants.
plz help me out here.
thanks & regards,
(2,922 Views)
What happens exactly when you see the memory error? Can we see your code?
With datasets that large you have to be very careful about memory management.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,900 Views)
hello ,
thanks for reply.I am attaching my Vi. It has some error also.plz look into it.
X and Y are my co-ordinates pairs.I will be having values for these and have to update for same.
(2,891 Views)
