Facing problem in Opening project in LabVIEW
Hello NI Team,
I am using MS Window 10 OS, I have Install the SW in this below mentioned order:
1) LabVIEW Development System 32
2) LabVIEW Real Time Module
3) LabVIEW FPGA Module
4) XILINX2017_2
5) NI RIO drivers
I am not able to get project in active form while open in LabVIEW, Please suggest.
Note: Working fine in Window-7
Prasant Kr Chowdhury
9818121640 / 7980582985
(2,378 Views)
It seems that you opened the project using LabVIEW 64bit. Try opening it with the 32 bit version!
Lucian
CLA
(2,325 Views)
Your Project Explorer says it doesn't "see" the Remote devices.  Your MAX display doesn't show the Remote Systems -- the picture cuts off right there, and you probably haven't expanded that setting, anyway.
Bob Schor
(2,263 Views)
