Fail on Labview installer builder
Dear support,
I follow this http://www.ni.com/tutorial/3303/en/#toc1
to do installer builder, but it fails, please refer to the attached file, how to fix this problem.
Regards
Sam
(3,865 Views)
There is no attached file.
(3,858 Views)
Here is the file.
Regards
Sam
(3,840 Views)
Loading product deployment information
*** Error (-33): File not found.
The ini file C:\MISC\Download\TestGear\GL840\GL100_240_840-APS(v124)\GL100_240_840-APS_ver1.24\APS Installer\setup.ini does not exist.
Additional details:
Error verifying distribution present: GL100_240_840-APS
Adding files to installer
*** WARNING ***
Cannot enforce the requested minimum operating system restriction because the deployment engine only supports Windows 7 Service Pack 1 or later. Resetting minimum restriction to Windows 7 Service Pack 1 or later.
Validating...
Copying files...
Scanning files...
Updating files...
Build complete successfully.
Done adding files
Preparing to build deployment
Copying products from distributions
Additional details:
Done building deployment
(3,838 Views)
Would you please check my attached file to figure out the solution for this problem?
Regards
Sam
(3,728 Views)
What are you selecting under "additional installers"? Obviously some don't exist on your machine, so they cannot be included.
(3,709 Views)
