Fail to calibrate PXI-5610
BRanhel
Member
Sory if this isn't the correct Board to post this question but I couldn't find a Calibration Executive Board
I'm trying to calibrate a PXI-5610 with the Calibration Executive 3.4.1 and I have the latest drivers instaled on my pc, the probem is that the calibration doesn't start and it gives this error:
"Open VI Reference in cex_Instr_RFSigGen_Init.vi->_NI 5610_RFSigGen Setup.vi->_NI 5610_RFSigGen Setup.vi.ProxyCaller
VI Path: C:\Program Files\National Instruments\Calibration Executive\InstrumentDrivers\LabVIEW\RFSigGen\rssma\cex_Instr_LabVIEW_RFSigGen_rssma_Init.vi
LabVIEW:  The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located.  Open the VI in LabVIEW using File>>Open and verify that it is runnable."
What can I do to fix this?
ps: I had to perform the calibration with Calibration Executive 3.2.1 because the client had some urgency...
Can anybody help
Thank's in advance
Bruno Ranhel
3 REPLIES 3
NIF_Vincent.O
Active Participant
Re : Fail to calibrate PXI-5610
Message contains a hyperlink
Hi BRanhel,
Please take a look at this knowledge base. This is for Calibration Executive 3.3.1 but it could work for the 3.4.1
Best Regards,
BRanhel
Member
The problem appens before the selfcalibrate, is not a failed value during the calibration!!
BRanhel
Member
The problem isn't a fail calibration due to the limits.
The problem is that the calibration doesn't even start!!!
