Failed to compile: Cannot convert source type code 0x70 to destination udclass
As the title tells...
I get the following error: "Failed to compile: Cannot convert source type code 0x70 to destination udclass". It is regarding the VI, selectionSort, which contains a "Call by reference" node. If I remove the node everything is fine (of course) when added and want to save I get the error.
Is it possible to fix? Did I do something wrong?
(3,114 Views)
In "wgtk_selectionSort.vi", your strictly typed reference to "Less comperator" is bad. Try Right-cliking it and selecting "Select VI Server Class > Browse..." and selecting the lessComperator.vi again. I got it to compile properly in LV 2011:
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,092 Views)
