Failed to generate Labview Wrapper from Labwindows dll
The error message is The following symbols are not defined:
_VI_FUNC; ViStatus;
They are definded in visatype.h but do not know what lines need to add to the .h file.
The Labwindow to Labview Driver conversion is for Kikusui PLZ164WA Electronic Load, but can only find Labwindows driver of a close model (PLZ153WA)
(3,093 Views)
Hello aha,
I am a little bit unclear about what your problem is exactly.  If your problem is that you need help creating a wrapper, perhaps the following information will be helpful.  The links contained in this article give some great information on how to do this.  http://digital.ni.com/public.nsf/allkb/06ECDC689DDA0F3D862574440074CD95?OpenDocument
Hope this helps!
(3,070 Views)
