Failed to load shared library KE6485_32.DLL
Hello!
I use picoammeter Keithley 6485 connected to real-time target NI PXIe-8135 via GPIB.
I try to deploy my labview program in real-time target, but error occured:
I've installed I/O layer for Kiethley and driver for Kiethley 6485 on my PC. Also I've copied KE6485_32.DLL to the ni-rt/system/ on RT-target via FTP.
When this error occures, on RT-target a message displayed:
" Error! instrsup.dll not found! (dependency)
Error loading 'WINMM.dll': Missing export '__CxxFrameHandler3' from 'MSVCRT.DLL' "
But in ni-rt/system/ exists instrsup.dll.
How can I avoid this error? Thank you.
(3,490 Views)
Hello Pavgran,
This may be caused by a corruption or a permissions problem. I would try deleting the library under the instrument drivers in your file structure and re-load them. It also may be helpful to reformat the controller and reinstall all of the softwware on the device to ensure a clean start with all the necessary drivers and files.
Andy M.
(3,452 Views)
