Failed to load under Mass compile
I am having following problem when I tried to Mass Compile:
#### Starting Mass Compile: Mon, May 14, 2007 10:20:12 PM
  Directory: "C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\addons"
Failed to load (C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\addons\NXTToolkit\shared\NXTToolkit.GetRelevantContexts_8_0.vi)
Failed to load (C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\addons\NXTToolkit\shared\NXTToolkit.OpenVIRefInContext_8_0.vi)
Failed to load (C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\addons\NXTToolkit\shared\NXTToolkit.RemoveScrollbars_8_0.vi)
#### Finished Mass Compile: Mon, May 14, 2007 10:22:26 PM
Please help me what I am doing wrong?
Raj
(3,268 Views)
Are they for the same version of labview ( i.e _8_0 not 7.1)
Regards
Ray Farmer
Regards
Ray Farmer
(3,262 Views)
Hi Ray,
I am using LabVIEW 7.1 Student Edition, I did install Dynamic Block Update and then install LabView toolkit for NXT as per instruction I did Mass compile and I received this error. I tried first sample and it did not show the NXT Toolkit palette I did found it [search] could not make sample.
Appreciate your help.
Raj
(3,251 Views)
Is there a reason as to why you are trying to Mass Compile?  The mass compile seemed to fail with the NXT platform - I would highly suggest you look at the following Discussion Forum postings in regards to NXT and the following tech support with Legos
Nadim
Applications Engineering
(3,205 Views)
Hi Nadim,
I was following ftp://ftp.ni.com/evaluation/mindstorms/LabVIEW_Toolkit_for_LMS_NXT_Getting_Started_Guide.pdf which explains on page 3 and one more thing I don't see is the icon on page 4 which is Sound Sensor ICO for NXT?
Help appreciated
Rajendra
(3,194 Views)
Rajendera-
Nadim is right, this is a better post for hte Lego forums. It sound like you might be missing a few pieces of the toolkit however. Have you tried checking to see if those VI's exist in the correct location? I would suggest either repairing or reinstalling the toolkit as it sounds like part or all of it is missing.
Xaq
(3,152 Views)
