Failed to run parallel path when using call library function node in LV2009
Hello Rob,
Is there anything else I can help you with or you would like more information about?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 13
(873 Views)
Hi Thierry,
not at this moment.
I'm an old-time LV user but last time I wrote a 'real' Labview application was in version 5 - so I'm just a bit rusty ...
I could really do with some elbow grease but in the mean time this forum provides me with some WD40 to loosen up a bit Smiley Happy
Rob
Message 12 of 13
(860 Views)
This made me think of the following image:
http://cdn.randomfunnypicture.com/pictures/907two-problems-in-life-wd40-ducttape.jpg
Kind Regards,
Message 13 of 13
(853 Views)
