Failed to uninstall and re-install any software from NI Developer Suite
I have noticed that some DLL's are missing when some NI device driver tried to load themselves at startup.  When I tried to uninstall any software from NI Developer Suite, I will get multiple of Error 2705 and 1603 boxes and no NI software can be uninstalled from my computer.
When I tried to re-install NI Developer Suite (using Fourth Quarter 2008 distribution DVD for LabVIEW 8.6), I will get a message "TARGETDIR is undefined, the Directory table seems malformed. Aborting...".  Nothing from NI Developer Suite can be re-installed on my computer.
I tried the tricks that others have posted in the Knowledge Base related to the Targetdir issue, creating a new admin account to run the installer, creating a new Documents folder, etc.  None has helped.
Is there a way that I can manually remove all NI software and then re-install them?
Thanks for your help.
Message 1 of 16
(6,301 Views)
I guess you dont have administrative rights to perform the operation. Confirm whether you see the same trouble if you are logged in as an administrator.
Message 2 of 16
(6,282 Views)
Non english operating system? [broken link removed]
Message 3 of 16
(6,281 Views)
Thanks for the reply, I did log in as an administrator and it is an English operating system.
Message 4 of 16
(6,267 Views)
What operating system are you using?
-Zach
Message 5 of 16
(6,257 Views)
The operating system I am using is MS Windows XP Professional Version 2002 with Sevice Pack 2.  My computer is Lenovo ThinkPad W500 with Intel Centrino 2 vPro processor, 2.53GHz, 1.98 GB RAM.
Message 6 of 16
(6,247 Views)
MJ,
In the past I have used a utility called MSI Blast to remove NI software.  Here is link to the app and the instructions.
https://forums.ni.com/t5/Multifunction-DAQ/i-am-looking-for-MSI-Blast-a-utility-to-remove-NI-DAQ-dri...
Message 7 of 16
(6,235 Views)
As the previous poster said, MSIBlast is an option altough I do not normally like to recommend it - but it is normally very effective. Are you going through Control Panel and Add/Remove programs when trying to uninstall? Also, can you post a screenshot of the error?
-Zach
Message Edited by iZACHdx on 01-06-2010 02:51 PM
Message 8 of 16
(6,232 Views)
I did use the Add/Remove programs from Control Panel when I tried to uninstall the NI programs.  And I got Internal Error 2705, Directory (see below).  After clicking OK, I then get Installer Error 1603.
I would like to try MSIBlast as I am running out of options.
Message 9 of 16
(6,223 Views)
I got the same errors (2705 and 1603) when I tried to uninstall the NI programs from MSIBlast.  Non of the NI programs can be uninstalled nor repaired from MSIBlast.  Should I proceed with rest of the manual uninstallation steps as specified in the MSIBlast help file?  What if I still cannot re-install the NI programs after my manual unstallation?  I could lose the other half of my working system.
Message 10 of 16
(6,212 Views)
