Failure: load.cpp, line 4066 - cannot open file
I cannot open my .vi file because of the following failure:load.cpp line 4066. What the reason is and how can I open my file to modify it?
(2,965 Views)
Hi Iron,
I don't know which version you have. If the error is reproducible you should report it to NI support along with your VI and the file LVfailure.txt. It seems your VI contains some insane objects. You can ask NI to remove the insane objects and send your VI back to you. You have to enter the deleted code again. If your VI is small redo it again from a new started LV with a new VI.
I hope they can help you
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,965 Views)
It definitely sounds like your VI is corrupt. There is some object or variable in your VI that can not be read by LabVIEW. As Waldemar stated, if we know the version of LabVIEW you have, we could try fixing it in a newer version on our machines if we have it. Otherwise, contact NI and they may be able to help you with it.
J.R. Allen
(2,965 Views)
I realized this kind of error as well. The most helpful way to ship around
this problem is simple reloding if the whole
labview platform including the putative vi. In every case
the vi runs without any problems after restarting the platform.
"waldemar.hersacher" wrote in message
news:50650000000500000070C80000-1042324653000@exchange.ni.com...
> Hi Iron,
VI.
> Waldemar
(2,965 Views)
