Failure : "image.cpp", line 11472
Error occurs when printing
(2,894 Views)
I have had to deal with these sort of failures a few times in the past. I have almost always been able to find the correct answer by using the following link from NI's website. There are a number of suggestions there to try. It may not be the solution but these suggestions have always worked for me. Good luck!
LabVIEW Internal Errors (Failure in XXX.c / XXX.cpp at line YYY)
-scraggs99
(2,894 Views)
Which version of LabVIEW and operating system are you using? There was a known issue with LabVIEW 6i under Windows 98/ME systems. There are a number of workarounds however, that will hopefully satisfy your application needs.
Workarounds:
1) Use bitmap printing or black&white PostScript printing.
2) Or, Print to HTML, then print from a web browser.
3) Or, Print from a Windows NT/2000 machine instead of a 9X/ME machine.
Some users have also corrected the error by removing all other network & fax printers that were not being used and then reinstalling the printer's driver.
Jonathan Hildyard
(2,894 Views)
G'day Jonathon,
Thanks for the reply.
OS - Windows 98SE
LabView - 6.0.2
(2,894 Views)
