Failure: "linker.cpp" line 2183
I was launching my Robolab application when I got the above error message.
(2,692 Views)
These are the kind of errors that happen rarely and are seldom repeatable. Can you duplicate the error? If not, don't sweat it -- stuff happens... If it is reproduceable, reply with a bit more detail ablout the application and we can work on it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,686 Views)
I get this same message every time I try to launch Robolab. it is consistent.
What kind of further information do you want?
(2,685 Views)
Assuming that this application did work at one time (right?) try to think of anything that might have changed or anything unusual that happened. For example, did the computer crash while you had the application open. Have you editied any thing or installed any new drivers? Finally, does the application run on another computer? Also try restoring an old copy from a backup to see if it works.
Mike...
LabVIEW Champion
(2,675 Views)
