Failure "save.cpp", line 1427
i have this failure when i build an application
any ideas to solve it?? and to explain it
(2,970 Views)
Hello Hors,
Can you give me please more information about your application to detect problem.
Thanks.
Sanaa TAZI
Application Engineer
(2,970 Views)
Hello Sanaa
The failure doesn't appear each building of application. My application uses about 500Vis and a lot are called dynamically. This application makes measures driving 5 devices (IEEE).
What sort of information do you want?
Thank you very much for your help
Hors
(2,970 Views)
Hello Hors,
Can you give me please :
1 - The version of LabVIEW that you use
2 - Your OS
3 - Reference of devices that you use
Have you try to build your application in other PC or other OS?
I'm wainting for you response.
Sanaa TAZI
(2,970 Views)
Hello sanaa,
I use LV6.1 with windows XP.
The different devices are SMT02, audio analyzer UPA, Power Supply NGSM32/10 from Rohde &Schwarz.
I tried to build it with another PC but it is the same configuration. It is difficult to change the OS beacause I would have to make a lot of modificatio on my application (Excel..)
Thank you very much
hors
(2,970 Views)
I suggest you to try to built an other application. Basic one. Just to know if you can do it.
You should also try to isolate the problem by
dividing your application and using the recompile function to isolate the offending VI.
Sanaa TAZI
(2,970 Views)
