Failure to Read File
Salutations,
I am incapable of reading the file (showcase of the data below).  When I read the file, it returns all 0's, instead of the expected values.  If you convert the file to a .csv, you can see it using excel, but  If I try to read that file, it also fails into nothing but 0's.
I am using the "read from spreadsheet vi" and applying a comma deliminator with a %d format.  I output this information onto the front panel of my VI using an indicator.
example piece of the data that should be read:
"4","ACCELL","Accell X","No Filtering","not used","not used","Accell Y","No Filtering","not used","not used","Accell Z","No Filtering","not used","not used","TRUE"
"4","1","1","26","82","0"
"4","1","1","26","85","0"
"4","1","1","26","87","0"
"4","1","1","26","90","0"
"4","1","1","26","92","0"
"4","1","1","26","95","0"
"4","1","1","26","97","0"
"4","1","1","26","104","0"
"4","0","1","26","106","0"
"4","0","1","26","106","110"
"0","2","0","0","1","90","2","212","1","58"
Thank you,
Smith
(2,882 Views)
Problem solved.
Thanks anyways.
(2,879 Views)
Smith,
How did you solve your problem?  It just might help some one else!
Andy F.
(2,856 Views)
