Famos File Creation
Has anybody any experience of how to create FAMOS compatible files using Labview?
Thanks & Regards,
Paul Towle,
Senior Engineer,
Luk Leamington.
(3,956 Views)
I am using FAMOS, version 3.2. I have created FAMOS files according to the .dat file description in the imc Curve Manager manual version 3.2, chapter 9 (File Format).
I use subVIs for creating the |XX keys for the FAMOS file format. Attached example FAMOS Key CB.vi. I have corresponding VIs for each key that is needed for the FAMOS file format. The file is created in a main VI that concatenates the key strings from each subVIs and writes the complete string to a .dat file using the Write Characters To File.vi (found from the File I/O subpalette in the block diagram Functions palette).
Note that the raw data in the |CS key need to be reversed from big-endian representation (used in LabView) to little-endian representation (used in FAMOS). Attached example Reverse Byte Order in Double Number.vi.
Message Edited by Tom C on 08-10-2005 02:49 AM
(3,912 Views)
hello,
have you realised other programm to read a FAMOS file (in .dat) ??
because I try to read a famos file but when I watch it in a graph, it's not the same signal that in FAMOS .
thank you in advance
Xavier DECLERCK
I'm French so excuse me for the faults
(3,723 Views)
