Fanuc 1553 card problems
Hello every one  .i have an application which uses  GE Fanuc QCP1553 card   .i  m using RT system as BUS controller .The application is working fine but the problem is that  when i create exe and set as startup application i m not able to communicate with it host .when i deploy the same application works fine . can any one help me to get out of it ?
Message 21 of 23
(689 Views)
How do you set up the BC to read the status word from the RT? thanx
Message 22 of 23
(623 Views)
I had that same problem...had NI here and we could not get it to work...this was 3 years ago or so
Message 23 of 23
(622 Views)
