Fanuc LRMate 200iC Interfacing
The first thing you really have to know is whether it is really Ethernet/IP (IP = Industrial Protocol) or it's an Ethernet connection that uses TCP/IP (IP = Internet Protocol). As you can see Ethernet/IP uses defined ports that are NOT 546 and 547.
The wireshark dump is pretty brief. I'm not at all convinced that you are showing the relevant section.
Message 11 of 16
(2,615 Views)
Okay, I have restarted wireshark and then connected from the software to the product.  Included is the wireshark information - I hope this helps.
Thanks for the advice.
metzler CLAD
Message 12 of 16
(2,603 Views)
That lists the documented ports for Ethernet/IP (Industrial Protocol)
Message 13 of 16
(2,588 Views)
You said "That lists the documented ports for Ethernet/IP (Industrial Protocol)"
I assume this is because the EtherNet/IP-2 port shown under Transmission Control Protocol is 44818, so it is Ethernet/IP (Industrial Protocol).
Now the question is, where do I go from here?  After the connection is established, it looks like the communication is UDP on ports 64079 and 2222.
metzler CLAD
Message 14 of 16
(2,566 Views)
So, getting back to the original question....   Which would you now recommend to interface with a Fanuc robot, Modbus/TCP or EthernetIP?
Dan
Message 15 of 16
(2,561 Views)
I have used the NI EIP module on a big project recently, however never directly interfaced it with a Fanuc robot (I haven't built a robot-machine since the EIP module was released).
I have only used the Modbus TCP (DSC) package, and it worked pretty nicely. I spent some time manually locating bits in the Modbus pool, but I believe a call to Fanuc CRC (tech support) would aid in this tremendously (I was missing the Modbus protocol roadmap).
I used 16 in/16 out. Mapped the UOP's to modbus-outputs on the Fanuc, and had a 5-bit GI/GO to send RSR commands and other integers. Again, there may have been an easier way, and Fanuc should be able to help set that up.
All that being said, the NI-EIP module worked very nicely for me on a recent project. I wouldn't be surprised if it worked just as well talking to an EIP-equipped Fanuc robot.
HTH.
-Ryan
Message 16 of 16
(2,557 Views)
