Fast Data Display with Decimation (XY Graph)
There is an excelent NI application note detailing how to efficiently display large amounts of data on a graph by utilizing a decimation algorithm; however, the example code is designed for fixed-rate sampling. Has anyone written code that would be applicable to variable-rate sampling?
Inputs: XY data arrays, graph width
Outputs: reduced XY data arrays
(NI Developer Zone > Development Library > Measurement and Automation Software > LabVIEW > Development System > Optimizing Applications > Managing Memory > Managing Large Data Sets in LabVIEW)
(3,874 Views)
That is a very good question. I have not seen an example like that. The main changes that you would need to implement is the way you create you array of min/max. You can use the index of the min and max values to extract a value form the X array. Now you can save that pair into the array in the right order.
I hope this helps. Let me know if you have any questions.
Juan Carlos
N.I.
(3,874 Views)
