Fast steering mirror and labview
   Hello! I have fast steering mirror ( FSM-300) and USB-6008 device. My goal is to be able to conrol x and y axises ( by controling the voltage). If I am able to control it, I can create different kinds of shapes, created by laser on the screen.
   I am using this code, which I am attaching.  Firstly, I tried to check my code on oscilloscope, and it seems it doesn`t get a signal, it looks like some noise. ( i am attaching the photo of noise). USB device seems to be working fine, because its diode is turned on. I use LABview 2020 community edition and  DAqmx 21.3  As long as I am concerned the compatibility is okay. I also attach the pinout and signal description .I connected two wires, one with 14 pin and the second with 16th pin and connected them into y-axis of the oscilloscope.What could be the problem?structure.pngKakaoTalk_20211115_185011704_02.jpg
(2,121 Views)
Accepted by topic author kimcheese
Please connect as shown in the below image.
AO0 - X
AO1 - Y
Don't forget to connect the GND to BNC shield.
Open the highlighted example,
Santhosh
Soliton Technologies
(2,100 Views)
