Faster waveform generation switching between case?
I have a PCI 6251 and I am using this to do waveform triggering based on the input signal.
Here is my flow:
Whenever the voltage signal from the analog input is higher than a user defined threshold. the analog ouput will output a square wave of +/-1V with 20kHz. Otherwise, the same analog output should remain idle.
I wrote a VI (please see the attachment) with case structure. I used DAQ assitant as the input and output, and passed the signal between two while loop.
I am wondering if there is any better module to speed up the one I have attached?
Best,
Matthew
(3,548 Views)
Don't use express VIs. They are inherently inefficient inside loops.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,545 Views)
Thanks Mike!
May I know what shall I use?
Best,
Matthew
(3,536 Views)
You have an entire palette for DAQmx functions and numerous examples.
Why the separate loops and what is the purpose of the delay?
(3,515 Views)
Read this excellent White Paper.  If you need more information, go to support.ni.com and look for DAQmx in Tutorials.
Bob Schor
(3,481 Views)
